Working from the top down, starting with the treble unit.
Not to be compared with any other specific tests; all testing conducted on a finite baffle; 9" wide, 22" tall, rounded edges; representative of somewhat typical enclosure dimensions.
Curves taken on axis, 15 , 30, and 45 degrees off axis.
Distortion plots taken with drive adjusted for 90 dB output at 1 meter.
There are many possible selection criteria- SPL linearity, off axis response, distortion; even so, considering the many ways in which drivers can differ, which are most important? You will have your criteria; I will have mine.
Seas 29TAFW
This is a newer driver in the Prestige Series from Seas. Hard dome, with a shallow waveguide that covers the magnetics mounting screws. Off axis behavior is not unexpected, with no phase shield.
Distortion is quite low above 3-4 kHz for a tweeter in this price class
Response droop at 45 degrees or even 30 degrees is unfortunate- perhaps we should name this the Needa tweeter, for another underperformer, Captain Needa. More basically, we Needa 'nother tweeter.
Seas 27TBFCG
Here we have a tried and true Storm Trooper. Not very pretty, with the Hexgrid cover, but get's the job done surprisingly well, considering the low resource allocation. Due to it's phase shield, response holds up well to 15 kHz even to 45 degrees off axis. 30 degrees off axis looks as good as many competing models on axis.
Third order distortion is quite low from 2 kHz up.
And, most importantly, it comes in black.
Seas 27TDFC
Seas 27TAFNCG
This driver is used in the NHT Xds system. Frequency response holds up well to 30 degrees off axis, and the distortion in the range above 3 kHz is consistently low, though not matching the levels of some of the better performers.
RS28a
A long time favorite in many parts of the Rebel Alliance, there are similarities of design with the 27TBFCG. But off axis response doesn't hold up quite as well. Distortion is comparable to the Seas, though differing in details. Above 5 kHz it is almost vanishingly low. And as it too, is black, and doesn't have a hexgrid cover, this may edge it ahead of the Seas for those not seeking as much output at 15 kHz and 45 degrees off axis.
Focal Tc120tdc
Seas Millenium Excel
The Millenium Excel has been a long time favorite of the high end DIY crowd in the early part of the 21st century, and is used in some well known designs, including the Thor, and Sigfried Linkwitz's Orion. Is it past the sale date at this point? The upper range distortion is fair but not stellar, but note that it doesn't increase significantly at 90 dB all the way down to 1 kHz. Is this a better trade-off? This sample and it's sibling have never displayed displayed the ruler flat frequency response some claim for this tweeter, not even when measured by MarkK.
Accuton C30N-6-24
Now we have reached the Grand Moff price class. Note the difference in the on and off axis curves of this hard dome without phase shield, compared with the Seas 29TAFW above. Could there be something to the concept of an inverted dome tweeter?
Distortion plots show clear evidence of resonant amplification of harmonic products; and also suggest that a crossover point above 2 kHz is advisable.
Accuton C25N-6-13
Scanspeak D3004/662001
The last to be acquired and tested for this lineup, it exhibits some interesting and puzzling characteristics.
The on and off axis curves seem to indicate substantial effort in the dome and waveguide design to optimize off axis behavior- 45 degrees at 15-17 kHz nearly match the reference level. Overall, it will probably have the most subjectively flat response off axis.
Distortion is intriguing but puzzling- the 2nd order distortion is actually reasonable in level, but looks high because the 3rd order distortion is so much lower- about 20 dB lower. At 2 kHz, the only competitor is the 27TBFCG; above 3 kHz, there is no competitor for 3rd harmonic distortion; it IS vanishingly low, not almost.
D3004-660000 "Air Circ"
D3004/660000 Air Circ Axis Curves
D3004/660000 Air Circ NF 4"
D3004/660000 Air Circ Distortion at 92 dB output
Strengths and weaknesses seem to be as individual and characteristic as their designers and companies. But two possible winners do emerge- the 27TBFCG for those of a sensible inclination or limited means; the D3004/662001 for those with deep pockets and demanding tastes.
Seas 29TAFW
Seas 27TBFCG
Seas 27TDFC
Seas 27TAFNCG
RS28a
Focal Tc120tdc
Accuton C30N-6-24
Accuton C25N-6-13
