Rotel remote (RR-969) going bad?
  • rotel&energy
    • 104
    I've had the RR-969 since I purchased my 1055 almost 4 years ago. I use it for the receiver, cd player, dvd player, and TV. Recently, I lost the "down" or "back" button portion of the Channel (CH) button. Batteries are fine. I can go up through TV channels, but not down. Everything else works fine. I guess it could be worn out, but I figured the channel up button would go out just as quickly? Anyone else have this, or a similar, problem w/ the remote? Am I naive to think that the remote should last this long?
    Christopher
  • Kevin D
    • 4601
    So the CH down doesn't work on every mode? Remote is covered by the warranty too, so I would just send it in with your 1055.
    Kevin D.
    • rotel&energy
      • 104
      Yeah, it doesn't work on any setting. I thought the remote only had a 1 year warranty (I've had it for 3 years)?
      Christopher
      • Kevin D
        • 4601
        I honestly never checked if the warranty was different.. I'm sure if you ask nicely they would replace it anyway to help ease the troubles with your 1055.
        Kevin D.
